LabVIEW PEAK Fitting
I am trying to detect a peak in LabVIEW and need to only record the position of the peak in time so i can calculate the difference in time between the centroids. Here is the attacthed vi. Does anyone have any ideas on how i can do this.
(1,570 Views)
Hi Andrew,
do you mind to provide an example data file, too?
I cleaned up the "pulse finder" a little bit:
Is there a reason you scale femto-/picoseconds by 10P/10T instead of 1P/1T? (Switching the display format of such numerics to SI display might prevent such silly errors…)
(1,541 Views)
Hi gerd W here is some data
(1,537 Views)
