LabVIEW Option modification
I would like to learn how to modify the LabVIEW -> Tools -> Options. All the parameters under Option window. Is there a file which you can modify or apply changes by using the batch file?
max
(4,558 Views)
So the obvious question is "Why?".  One generally does not "mess" with the built-in functionality of a complex programming system such as LabVIEW.
(4,514 Views)
One potential application might be to export and import the Labview environment settings to replicate a configuration?
(4,507 Views)
With the LabVIEW executable is a LabVIEW.ini.  That configuration file is what holds all of your settings.  I keep a copy available for new installs.
(4,495 Views)
For clarity, the path is (assuming installed on C:/) C:/Program Files {,(x86)}/National Instruments/LabVIEW 20[01][0-9]/LabVIEW.ini
The path is probably the same for versions older than 2009(?) but I don't know how to give the path names there 😉
You can have (annoyingly, perhaps) separate configurations in Program Files and Program Files (x86) on a 64 bit system with both 32 and 64 bit LabVIEW installed.
One possible simplification is to put the ini file somewhere shared (like Dropbox) and then add symbolic links to it.
On Windows, you can do this (probably requiring administrator access to create/move files in Program Files) with a command line command like
mklink "C:\Program Files (x86)\National Instruments\LabVIEW 2017\LabVIEW.ini" "C:\Users\<username>\Desktop\LabVIEW.ini"
the first path is the link, the second is the destination/target.
mklink /?
provides some description to remind you.
Edit: LabVIEW will read this file, but then creates a real file in place of the symlink when you close. So you can use it to set LabVIEW options, but not to share LabVIEW options between computers when you change them inside LabVIEW 😞
GCentralI'm attending the GLA Summit!
(4,484 Views)
correct, to standardize the config for all the programmers in order to enforce internal standards.
(4,444 Views)
