LabVIEW Object-Oriented Programming: R&D Technical White Paper (LV8.2)
LabVIEW++ would make it sound like a different language. The whole point is that it isn't -- it's just a feature in LabVIEW. It's been a tricky proposition to strike the right balance. Besides, when we did consider something akin to LabVIEW++, one developer pointed out that this would be better:
A joke, of course. Because, again, at the end of the day, it's just LabVIEW, now with OOP.
Message Edited by Aristos Queue on 08-11-2006 11:21 AM
Message 11 of 16
(2,774 Views)
A dynamic dispatch VI is a member of a class with the class input and output on the connector pane set to dynamic dispatch instead of optional, required, or recommended.  At run-time, the proper VI will be run, depending on where in the class hierarchy the data in the input wire resides.
Message 12 of 16
(2,710 Views)
"Aristos Queue" <x@no.email> wrote in message news:1155314407461-403184@exchange.ni.com...
&nbsp;<img src="http://forums.ni.com/attachments/ni/170/200237/1/lv+1.PNG">
lv+1.PNG:
For a minute I thought NI was going to rename LabVIEW to LabVOOP...
Regards
Wiebe.
Message 13 of 16
(2,690 Views)
FYI,
The white paper posted in the original post has been converted to an online Tutorial in the DeveloperZone.  Please reference LabVIEW Object-Oriented Programming: The Decisions Behind the Design for the most up-to-date version of the material.
Take care,
Travis H.
LabVIEW R&D
Message 14 of 16
(2,661 Views)
OO is not a programming language. It is a programming methodology (and some say a programming philosophy.) You need a programming language anyway, which should support the methodology.
www.vartortech.com
Message 15 of 16
(2,634 Views)
Hmmmm gonne read it tomorrow. But I was expacting LaTeX to be typesetting not Word!
Message 16 of 16
(1,370 Views)
