‎10-01-2015
02:17 AM
- last edited on
‎05-28-2025
04:47 PM
by
Content Cleaner
I have a cRIO which runs Linux RT (x64). I'd like to use a 3rd-party C++ library from an RT VI. The library has functions that aren't compatible with LabVIEW's Call Library Function Node (for example, functions that accepts a C++ string input). On Windows, I'd create my own wrapper library using LabVIEW Manager features to convert between LabVIEW types and C++ types.
Is it possible to do the same for Linux RT targets? Is there a version of labviewv.lib (either 32-bit or 64-bit) for Linux targets? (I only have a Windows development machine)
Thanks!
‎10-02-2015 02:58 AM
It's not possible to create a personalized library with labview manager under RT Linux. Because you can import code on a RT Linux but not develop. However you can create your own library on Windows and export it on RT Linux target.
Best regards.
‎10-02-2015
03:58 AM
- last edited on
‎05-28-2025
04:48 PM
by
Content Cleaner
Hi elodie.k,
Yes, this is what I want to do.
To be clear, I want to make a library using the C/C++ Development Tools for NI Linux Real-Time, just like this tutorial: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGvGCAW&l=en-US
However, I want my library to call LabVIEW Manager functions. So, I need a version of labviewv.lib that is compiled for Linux. When I have this file, I can link it to my own library. Where can I get this file?
Thanks!
‎10-02-2015 04:34 AM
You needn't to intall labviewv.lib on your RT linux target. Just develop your application using Labview MAnager Functions on Windows and after deploy it on Rt Linux target.
Best regards.
‎10-02-2015 05:00 AM
Ah, I didn't realize that. I'll give it a try; thanks!
‎10-02-2015 06:26 AM - edited ‎10-02-2015 06:31 AM
Elodie is correct.
Unlike the Windows DLL COFF format that requires an application to explicitedly import functions from other shared libraries, the ELF format used on Linux works differently. The shared library loader on Linux will by default search the entire export tables of all previously loaded ELF object code modules (ncluding the main executables export table if present) for missing symbols when a new module gets loaded. If it doesn't find it there it will search the cache created when running ldconfig. The import table in a shared library only contains a symbol name and an optional entry identifying the shared library file that should contain the symbol. The enire linking is performed at load time by the shared library loader.
A Windows DLL needs to contain specific code to link the entry point in the external module to the code inside its own module and that is what the link library labviewv.lib is doing, nothing more. For non-Windows systems this import link library is completely unneccessary.
One catch you should be aware off is that simply copying your shared library file to the realtime target is usually not enough. You have to place it in one of the directories that ldconf will search (all fully configurabele with configuration files as everything else in Linux) and then run ldconf to update the ld.so.conf cache that the shared library loader will use to find shared libraries.
‎10-02-2015 06:42 AM
