LabVIEW Interface for Arduino Error
Error -1073807360 occurred at VISA Clear in LabVIEW Interface for Arduino.lvlib:Init.vi->LabVIEW Interface for Arduino.lvlib:Arduino BlinkM.vi
Possible reason(s):
VISA: (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
As shown above, my attempts to use LIFA has given me no shortage of errors and problems. Currently, I have changed the checksum error which was mentioned in another form in the Arduino ide to equal zero which has fixed some error codes I had initially with the LabVIEW Interface for Arduino VI.
using my own VIs or example VIs I get this error. I've tried multiple com ports and uploading the Arduino sketch each time, then opening LabVIEW while having the ide closed with no success. all drivers and software are up to date and the Arduino LIFA_Base is uploading,
any help on the topic would be much appreciated.
(3,419 Views)
Possible reason(s):
Well to begin with LIFA has long since been deprecated and replaced with LINX
LINX is now supported on the HOBBYIST TOOLKIT forum
=== Engineer Ambiguously ===
(3,359 Views)
Accepted by PG2113
Hi
LIFA suited my needs is why I chose it,
but anyways
Completely removing all files and anything relating to the arduino and reinstalling a older version of the IDE such as the 1.0 version has allowed me to connect to the arduino successfully. The LIFA base arduino code still required the checksum value to be changed to zero in my case.
(3,351 Views)
