LabVIEW: File is not a resource file. The file is not a valid LabVIEW file
I have attached a zip file with the probolematic 'Create report.vi' within.
Message 11 of 34
(4,015 Views)
Hi Grant_C,
also inside the zip is it still a jpg.
Mike
Message 12 of 34
(3,999 Views)
Perhaps the actual code created a JPEG and named the image file with the same name as the VI and overwrote the .vi file. Smiley Surprised
Message 13 of 34
(3,986 Views)
my file seems to be corrupted out of blue.. the vi has DAQmx functions , to make some edits after customer input the vi was being edited and sudden'y it won't open... I have to install this file tomorrow.. any help is very much appreciated.
-Pallavi
Thanks...
Pallavi
Message 14 of 34
(3,873 Views)
Palchen,
After reading through the original discussion on this topic, it appears that the only way to fix this is to recover your file from a backup.  You can find documentation on this problem here.
Trey C.
Message 15 of 34
(3,862 Views)
Hi, my vi is also not working. Does anyone can help me. I spent much time for this vi but unfortunately corrapted. Please help me. Appriciate for help
Best.
Message 16 of 34
(3,845 Views)
Becidea,
The easiest way to recover a corrupted file is generally to load the latest revision that is not corrupted.  If this corruption occurred when the VI was sent as an email attachment then I would suggest zipping the VI in a folder before attempting to resend it.
Trey C.
Message 17 of 34
(3,833 Views)
Thank you, but unfortunately I didn't meet like this situation for 1 year:)). I need to write again.
Best.
Message 18 of 34
(3,817 Views)
Hi there,
I'm experiencing the same problem with my labview file which was my 2 months work. I saved when I exit but today morning I experienced the system hang, before I open the file, and after restarting I was popped with this error.  Any help regarding this is very much appreciated.
Message 19 of 34
(3,389 Views)
Hi CNRK,
as suggested before: use a VI from your backup!
You do have backups made for your "2 month work"?
Message 20 of 34
(3,363 Views)
