11-27-2015 04:19 AM
Hello everyone.
I need your help!
I am working with the FPGA frame grabber NI-PCIe 1473R connect to the camera links with Basler ral4096-80km.
I've ever used LabVIEW FPGA before.
I've got this problem for a while . I try to build the bitfile from the example "1-Tap-10-Bit Camera With Frame Trigger" but the error occur with the message
CLIP instance DRAM Bank 1 is configured with a CLIP declaration that is not valid.
Change the CLIP instance configuration or add the relevant CLIP declaration to the target.
When I click 'Show error' it lumps to lvproj file and the red '!' appear in tab DRAM0 and DRAM1.
I don't understand What's CLIP and don't know how to fix this issue.
Looking for your reply !
Thank you very much.
Racha
11-30-2015
11:04 AM
- last edited on
07-18-2024
06:02 PM
by
Content Cleaner
Hi Racha,
CLIP stands for Component-Level IP and is a way to incorporate FPGA IP developed in languages other than LabVIEW FPGA (VHDL, etc) into your LabVIEW FPGA project. You can read more about CLIP here.
The code you posted looks like the 1-Tap 10-Bit example for the 1473R from the example finder - is that the code you're using? If so, what modifications, if any have you made to the example? I don't see any CLIP configured in example when I open it on my machine, and everything builds successfully. If you've made any modifications to the code, try going back and just building the example as is to see if that builds successfully.
Also, what version of LabVIEW, LabVIEW FPGA, and IMAQ I/O are you working with? I'm using 2015, but if you're working with a different version, that may explain why the example I'm using is different than the one you posted.
11-30-2015 07:34 PM
Hi Ryan,
Thank you for your replying.
I connect the fpga-frame grabber with two camara links. Should I try to use this example?
I didn't modyfy anything in the code just oped it and try to build.
I use LabVIEW 2015, FPGA 2015 and Daq mx 15.1.1 .
Racha
12-01-2015 11:37 AM
The 1-Tap 10-Bit Camera with Frame Trigger example that you are working with doesn't have DRAM configured by default in LabVIEW, so it seems like another user may have inadvertently modified the example and saved it. The DRAM shouldn't be necessary, so try removing it from the project and then build the project again. To remove the DRAM declarations, just right click on the item in the project explorer and select delete.
As for your question about "should I use this example" - this example shows how to perform 1-Tap 10-Bit image acquisition with the 1473R, so if that's what you're trying to do then yes, you can use this example. This example also shows in general what the process of working with the FPGA on the 1473R looks like, so it's useful to refer to even if 1-Tap 10-Bit is not exactly what you're looking to do.
12-03-2015 02:13 AM
The DRAM declarations cannot be deletec . There is no delete button when I do right click.
still confusing with this issue
Racha
12-04-2015 12:53 PM
This is what the 1-Tap 10-bit project looks like when I open it on my machine (LabVIEW FPGA 2015, IMAQ I/O 15.0):
Are you opening this example directly from the example finder? Can you confirm that you're working with NI-IMAQ I/O 15? IMAQ I/O is a different driver than DAQmx.
If the answer to both of those questions is yes, it seems like something has happened to the example on your computer (i.e. someone made changes and then saved them without creating a new copy of the example in a different location). You should be able to restore the example to it's original form by deleting the example source files off your computer and then repairing the IMAQ I/O driver. Try that, and let me know if you still see the CLIP declaration in the project after doing so.
12-22-2015 10:17 AM
I had the same issue and followed your advice to remove the examples folder and reparint NI-IMAQ I/O driver, but the issue still existed. Please give further advice, thanks.
12-23-2015 06:18 PM
You can create a new project, add the PCIe-1473R as new target and then add new FPGA I/O (right click FPGA -> New -> FPGA I/O). This will add the Camera Link I/O. From there you can drop and drag VI from the existing project to the new project. You should be able to build the project from there.
