LabVIEW FPGA compilation
I have a problem with FPGA compilation. I am using single board rio 9602.
I have installed:
- Windows 7 operating system
- LabVIEW 2015 sp1 (32bit),
- LabVIEW 2015 sp1 FPGA module,
- LabVIEW 2015 sp1 Real-Time Module,
- NI CompactRIO 16.0- NI CompactRIO Device Drivers August 2016
- LabVIEW 2015 SP1 FPGA Module Xilinx Tools 10.1 (ISE 10.1)
I configured sbRIO in NI MAX, then created a project. Everything looks ok, but
when i am trying to compile FPGA vi with local compile server i see the message:
,,LabVIEW FPGA:  The compile worker cannot perform the compilation. The compile worker may be configured incorrectly for this compilation or it may be in an error state."
What makes me confused, in details i see:
"Compiling on local compile server
Compilation Tool: Xilinx 14.7"
but i have never used Xilinx 14.7
I have no idea where I made a mistake and what i can do to solve this problem.
I'd really appreciate any help!
Pic of error screen in attachment
(3,096 Views)
For 2015 SP1 the 10.1 compile tools are only needed for Virtex II FPGAs. The 9602 would be using the latest version of the ISE compile tools which are 14.7 and likely why they are being called out. I would probably try installing the 14.7 tools for 2015SP1 or just using the cloud compile option if possible.
https://www.ni.com/en/support/downloads/software-products/download.labview-fpga-compilation-tool.htm...
https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio...
(3,054 Views)
Thanks a lot. Its working 🙂
(2,990 Views)
