LabVIEW FPGA Single Cycle Timed Loop with FFT speed?
I have a PXI system with an oscilloscope capable of 100 Megasamples/sec and an FPGA module with an 80 MHz clock. I would like to perform an fft on the fpga in a single-cycle timed loop where the fft size is 80. This means that one FFT is done every clock cycle right? Does this mean that if I have my oscilloscope set at 100Megasamples/sec I should be able to do 100,000,000 / 80 = 1,250,000 fft's per second? I'm not sure if I'm understanding correctly.
(1,300 Views)
Have you tried to use standard examples?
It is not clear how you are going to perform FFT but I think there is something is missing in your description.
__________________________________________
The best way to thank, is to give KUDOS
(1,242 Views)
