09-02-2015 11:36 AM
Receiently I got the error 63085 when reading writing an array to the labview fpga. I'm using a 7845R Daq OEM. The documetation on the error says:
−63085 | NiFpga_Status_ControlOrIndicatorTooLarge | The FPGA Read/Write Control Function is accessing a control or indicator with data that exceeds the maximum size supported on the current target. Refer to the hardware documentation for the limitations on data types for this target. |
Im using a fixed point array of size 80? where in the documtation can i find the information this error refers to?
09-02-2015 11:56 AM
Did you follow the instructions and look at the help for your FPGA target?
As per this link (http://zone.ni.com/reference/en-XX/help/371599G-01/lvfpgaconcepts/pfi_data_transfer/), there are hardware specific limits on the size/data that can be transferred using front panel controls/indicators on FPGA targets which you are exceeding (80 FXPs is quite a lot in FPGA terms). To find the documentation for your hardware, see here: http://zone.ni.com/reference/en-XX/help/371599G-01/lvfpgahelp/fpga_target_docs/
I suggest you use a FIFO to transfer your data!
09-04-2015 09:43 AM
Your first link seems to be broken... I did switch to FIFO, however i was unable to figure out the limits for control/Indicator size. I tried to find the document that specified this for my device but was unable too. also there needs to be a better word for controls/indicators like the class they belong too. Anyhow thankyou very much for your reply Sam.
09-04-2015 08:20 PM
@Taylor_H. wrote:
Also there needs to be a better word for controls/indicators like the class they belong too.
From what I remember controls and indicators both fall under the class do controls. A property of the class determines whether it is a control or indicator, I think of it as a setting to decide whether there is read or write access to that object.
That inherits from GObject (Generic Object) which is basically every object (for lack of a better word) which is on the front panel or block diagram.
Doesn't really help out but it's another fun fact brought to you by VI Scripting.
