LabVIEW FPGA Error -61003
I am using a cRIO NI‑9054 to generate a communication frame signal using the FPGA.
Each bit is composed of three states of 600 µs each:
  • Start: 600 µs at logic 1
  • Data: 600 µs at logic 0 or 1 depending on the bit value
  • Stop: 600 µs at logic 0
I am using the attached VI to generate this signal. The VI is placed inside a Timed Loop that reads the elements to send from a DMA FIFO and passes them to the VI to generate the output signal.
However, when I compile the FPGA, I get the following error:
Can anyone tell me why this piece of code produces this error?
Regards
(643 Views)
Accepted by topic author kuroro_W
Hi kuroro,
As the error message says: you cannot use FPGA IO nodes inside a FOR loop, when that FOR loop is placed within a SCTL…
Two options:
  1. Don't use a SCTL to output your bits.
  2. Create code that follows all the rules for SCTLs and FPGA IO nodes.
(628 Views)
Hi GredW,
Thank you for your reply.
The error message was indeed clear, but it was pointing to every function inside the For loop (even the wait), which I found unusual. Since I’m new to FPGA development in LabVIEW, I couldn’t immediately identify the root cause.
After doing some research, I now understand that the code violates some SCTL rules. Thank you for pointing that out.
Regads,
(588 Views)
