LabVIEW FPGA Cloud Compile Service stuck on generating cores
HI,
Since I am using windows 8 I have to make use of the cloud compile server to compile my VIs.
However lately it has been stuck a lot at the generating cores phase.
Is here anything I can do to get rid of this problem ? Sometimes it just doenst seem to compile at all but sometimes it does compile. This is kind of annoying since I rely on this service.
Any advice?
(3,914 Views)
Accepted by topic author BastiaanO
How long does the compile get stuck there? If your application requires a number of cores, it can take a long time to generate all the necessary support files. For some larger FPGAs, this part can take several hours the first time you hit a new compile machine/instance. Luckily, the cores are cached so that might be why it is sometimes faster, it depends on which machines your compile is hitting.
(3,903 Views)
Hey Dragis,
Thanks for your reply. The longest I have seen it stuck was 40 minutes or so. At that time I figured something went wrong and I cancelled the compilation.
At least now I know that it is not stuck and that I need to be patient for a little longer.
Thanks for the clarification
(3,881 Views)
It would be nice if the locally-cached Core files would be passed over the network to the compile server.
I have a FPGA design which takes 2.5 Hours to compile locally and 4 hours in the cloud.  the difference? 1.5 hours generating cores.  You can ship a lot of data over the network in that time.
(3,662 Views)
