08-07-2019 07:06 AM
Hello!
Problem:
I'm simulating different sine and cosine waves to generate multiple signals. I applied FFT vi and extract the frequency components of them. I want to extract specific frequencies from multiple frequencies, for example, there are 100 frequencies data available and have to extract 20, 22,28) and after that apply a machine learning algorithm on them. Can you please tell me how can I do it?
Best Regards
08-07-2019 07:09 AM
Hi Chishti,
I want to extract specific frequencies from multiple frequencies, for example, there are 100 frequencies data available and have to extract 20, 22,28) … Can you please tell me how can I do it?
Use IndexArray on your array of FFT amplitudes!
What exactly is your problem?
Why don't you attach your VI?
08-07-2019 07:14 AM
Please check.
I received multiple frequencies (which I simulated in the attached vi). I want to extract frequencies only specific ones (my supervisor will give me later). Now how can I extract specific frequencies. After extracting specific frequencies I've to apply Linear Discriminant analysis to find the coefficients.
08-07-2019 07:28 AM
08-07-2019 07:32 AM
Please find the '17 version
08-07-2019 07:50 AM
Hi Chishti,
see this:
I changed your VI to use waveforms instead of plain arrays.
Now you get a waveform-like output containing f0 and df with the amplitude data. Now you can easily calculate the amplitude index from those additional values to pick the desired frequency values from your FFT data…
08-07-2019 08:06 AM
Can you post the VI, please?
08-07-2019 08:21 AM
I think it's not necessary.
Thank you so much for your quick response
08-07-2019 08:24 AM
08-08-2019 03:28 AM
I'm getting this error. I tried the solution online but it won't work. Did you get the same error?
