LabVIEW Datalogging and Supervisory Control Module - 64 bit
Hallo,
I was looking Datalogging and Supervisory Control Module for Labview 2021(64 bit). I couldnt find the 64 bit version of it.
My application is completely written in 64 bit labview 2021. now i want to use the DSC module in my program. can i use the DSC 32 bit with my current application?what are the practical problems i might encounter? are there any alternatives?
(1,899 Views)
If you have a license for LabVIEW 2021, then you can (also) install LabVIEW 2021 (32-bit).  I would imagine (but haven't tried this) that you could take your 64-bit Project, mark all the VIs as "separate from compiled code" and then be able to open it in 32-bit LabVIEW.  [Note -- if I'm wrong about this, one of my colleagues on the Forum can set us both straight].  Do you really need tie large memory space?
(1,876 Views)
