LabVIEW Crashes when Opening Project
Hey Guys,
I'm running into an interesting issue where LabVIEW crashes when opening a project. This is the second time I've run into this issue, on the same project. To get around it the first time I simply deleted and re-made my project, but since it's happened again, I need to figure out how to debug it. The symptom is that LabVIEW will crash when opening the project (sometimes I can see the "vi loading" screen) without any indication that crash has occured. It doesn't even launch the error reporter, the process just dies. Anyone know how I can go about debugging this?
(3,701 Views)
Accepted by xkenneth86
xkenneth86,
What version of LabVIEW? Have you ever had previous versions of LabVIEW on your computer? Can you attach a screenshot of the crash?
David H.
(3,644 Views)
Hey Guys,
Going to close this out. Traced it back to some broken calls to an Ethernet RIO chassis that were buried deep in the project dependencies and causing LabVIEW to crash.
(3,637 Views)
