LabVIEW Communications System Design software 2.0 with Data Communications
Today, through USB, I have Lab View software installed, and I want to install communication support software for various communications, including TCP/IP communications.
Please tell me which version of VISA or software I have that supports LabVIEW Communications System Design Software 2.0.
And even with VISA installed, there is no communication icon in the dialgram, so I would appreciate it if you could tell me how to get the communication icon and apply it.
(3,411 Views)
Accepted by oyw1022
Hello, oyw1022
You can install NI Package Manager for providing the correct drivers installation. If you don't want to use Package Manager, you can check, what version of LabView installed on your pc through the My Computer LabView folder. Every LabView folder got the version in the name of it. For example it can be C:\Program Files (x86)\National Instruments\LabVIEW 2019 which means that you are using 19-th version. Then you can find the suitable driver for it simply checking the documentation of the driver. Check from newer driver to older
(3,219 Views)
Thank you for your comments.
(3,208 Views)
You are welcome, oyw1022
(3,200 Views)
