LabVIEW, Can I synchronize a cDAQ device (9231) and a CAN device (9862) in the same chassis (9174)
If I can, can someone share a sample LabVIEW code?
Thanks.
Ian
(2,883 Views)
Hi Ren,
in which way do you want to sync those modules?
- Do you want to measure some analog data for each CAN message? Or for specific CAN messages?
- How accurate do you need to sync? ms, µs or ns? (Which CAN baudrate do you use?)
- Your NI9231 uses a delta-sigma ADC, which is hard to sync with other devices. Other kind of ADCs are easier to sync…
(2,840 Views)
GerdW,
Thanks for your response. I want to
1) measure a few (10-20) analog data signals for specific CAN messages. The CAN signals are updated at 100Hz rate.
2) start CAN and DAQ at the same time (by the same trigger signal, which I have found doable from the XNET example).
3) An accuracy about 1-2 ms is acceptable. The baudrate is 500kHz.
4) If I cannot sync 9231 with 9862 acquisition from the same clock base, and I just start CAN and DAQ by the same trigger, do you have a feel how long I could run data acquisition before the CAN and analog signals would be out of synch for more than 1-2 ms? module 9231 and 9862 are in the same 9174 chassis.
Thanks.
Ian
(2,833 Views)
CAN will be acquiring data at 256Hz, so an synch error of one sample, i.e., 4ms, is acceptable.
(2,825 Views)
