‎07-19-2018 11:21 AM
‎07-20-2018 06:17 AM
Hi Ren,
in which way do you want to sync those modules?
- Do you want to measure some analog data for each CAN message? Or for specific CAN messages?
- How accurate do you need to sync? ms, µs or ns? (Which CAN baudrate do you use?)
- Your NI9231 uses a delta-sigma ADC, which is hard to sync with other devices. Other kind of ADCs are easier to sync…
‎07-20-2018 08:49 AM
GerdW,
Thanks for your response. I want to
1) measure a few (10-20) analog data signals for specific CAN messages. The CAN signals are updated at 100Hz rate.
2) start CAN and DAQ at the same time (by the same trigger signal, which I have found doable from the XNET example).
3) An accuracy about 1-2 ms is acceptable. The baudrate is 500kHz.
4) If I cannot sync 9231 with 9862 acquisition from the same clock base, and I just start CAN and DAQ by the same trigger, do you have a feel how long I could run data acquisition before the CAN and analog signals would be out of synch for more than 1-2 ms? module 9231 and 9862 are in the same 9174 chassis.
Thanks.
Ian
‎07-20-2018 01:26 PM
CAN will be acquiring data at 256Hz, so an synch error of one sample, i.e., 4ms, is acceptable.
