LabVIEW Application Web Service Http request generates Windows Event ID 4625 : Logon attempt failure
I have an application web service running on my computer witch runs perfectly fine. However, every time I make a HTTP-request to the server it seems like that the web-server tries to logon to (windows, NI Authentication)? using the ApplicationWebServer.exe. I'm using no security things like API keys or user permission, just a blank http get request. Anyone have any idea what can be causing Audit Failure Event ID 4625 task to occur?
Best regrds
Message 1 of 8
(4,006 Views)
Good afternoon,
This behaviour has been reported with other people previously.  A possible work around to the situation is by changing the user rights to be given specific access to the windows share.
I hope this helps as a starting point in troubleshooting your problem.
Geo
Message 2 of 8
(3,967 Views)
Thank you for your reply! But can you be a bit more specific with what you men by "changing the user rights to be given specific access to the windows share." because I don't really follow.
Best regards
Message 3 of 8
(3,958 Views)
Hello, was a solution ever found for this? I am now experiencing the SystemWebServer.exe producing hundreds of Event 4625 per second.
My only choice was to disable the SystemWebServer.exe service, however, that renders the FPGA Compile Worker unusable.
How can I prevent these events? It is attempting a Kerberos login, but, it is not configured as such.
Message 4 of 8
(655 Views)
I resolved this by changing the "NI System Web Server" service in "services.msc" to use a specific account rather than the "Local System account". The 4625 errors in event viewer immediately disappeared and Web Server functionality was restored.Screenshot 2026-06-22 195510.pngScreenshot 2026-06-22 195510.png
Message 5 of 8
(641 Views)
Hi Gryffin,
I've looking to fix this for a long time. Unfortunately it didn't work for me. In addition to the "NI System Web Server" service do you also have to change the "NI Web Server" service to something other Log On?
Below is what mine is set to.
Message 6 of 8
(619 Views)
Hello ooth,
In my case, I am using a true "Local Account":
And I use this account for my service logon (rather than the "Local System account):
Also note that I did this for "NI System Web Server", whereas I see in your case you are doing it for the "NI Web Server". Perhaps you have a different case in which the 4625 event is being triggered by that process, but Event Viewer indicated (for me) that "NI System Web Server" was the problematic process.
To my understanding, this error results from the PC being a member of a domain (in my case it was attempting a Kerberos login) where running processes as "Local System" is restricted. I think if you use explicit credentials for an account associated with that PC, and run the service as that account, it may fix the 4625 error generation.
I hope that helps!
Message 7 of 8
(615 Views)
This bug reappeared, and I seemed to have stopped it while still maintaining functionality.
I had to:
1) Open Services.msc
2) Go to the "NI System Web Server" service
3) Go to the "Log On" tab
4) Click "Browse", "Advanced", "Find Now", select your username (in my case, "LAB"), click "OK" while your username is highlighted.
5) Having clicked "OK" with your username highlighted in the "Select User (Advanced)" window, it will now be listed in the "Enter the object name to select (examples):" box. Click OK again.
6) The "Log On" tab of the "NI System Web Server Properties (Local Computer)" should now have your account populated (in my case, .\LAB). For good measure, I would explicitly retype your password in the boxes.
7) Click OK, stop and restart the "NI System Web Server" service.
😎 No more 4625 events!
P.S. I upgraded from 2026Q1 to 2026Q3 and I needed to reapply this fix.
Message 8 of 8
(336 Views)
