LabVIEW & ActiveX (controlling WinAMP)
Hi.
Does anybody here know a way to control WinAMP through LabVIEW? WinAMP isn't
registered as an ActiveX component, neither can I find an .ocx installer for
it. I can't seem to find a list of command line options, so the EXEC
function can't easily be used.
Any ideas?
Regards
Steen
(3,569 Views)
No idea about winamp, but if you need a mp3 player for LabVIEW, you could use GAMP, the LabVIEW mp3 player, which you can find at http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&AB3096414BA2457D862568C500676FF7&cat=2E4161187E3DEB30862568660020BCC8
Hope this helps
(3,568 Views)
Hi Steen,
WinAmp doesn't use any ActiveX components. You can only control it by
sending messages to the application. Take a look at the developer site and
you will find a complete list of all messages. I already tried it sometime
ago with good results.
For sending messages you have to use the SendMessage or PostMessage function
of the WinAPI... therefor you need a WrapperDLL. You can write it for
yourself or look at some existing vi's.
good luck
Henrik
Steen S. Schmidt schrieb in im Newsbeitrag:
7zm57.2228$oH6.197432@news010.worldonline.dk...
> Hi.
isn't
for
> Any ideas?
> Regards
> Steen
(3,568 Views)
Thanks - I've made a dll-wrapper. It works perfectly. (I'm not too fond of
Media Player 🙂
Regards
Steen
(3,568 Views)
