LabVIEW 8.5 et objets.NET
Bonjour,
Je développe une application sous version 8.5 qui permet de communiquer avec un automate Unitronics. Le fabricant met à disposition un fichier assembly.net. Le problème est que je n'ai pas accés à toutes les classes des objets de ce fichier ("Cette classe ne contient pas de constructeurs publics" me dit LabVIEW). Or aprés renseignements auprès du fabricant, la classe dont j'ai besoin et qui n'est pas reconnue par LabVIEW est déclarée en "Public static". Existe-t-il un moyen de résoudre mon problème?
Merci d'avance
Message 1 of 9
(4,525 Views)
Please try posting in english here
I am developing an application in version 8.5 that can communicate with a controller Unitronics. The manufacturer offers a file assembly.net. The problem is that I do not have access to all classes of objects of this file ( "This class contains no public constructors" said LabVIEW). But after information from the manufacturer, the class I need and that is not recognized by LabVIEW is declared "public static". Is there a way to solve my problem?
Message 2 of 9
(4,514 Views)
Post in the french board for better response
Message 3 of 9
(4,513 Views)
Sorry, I didn't know that the forum was only in english.
Message 4 of 9
(4,485 Views)
No no dont go away. I meant this particular board is in english. As mentioned above you have an exclusive french board. Keep visiting........
Message 5 of 9
(4,470 Views)
It's OK. I go to the french board but I recieve no answer for my problem. Have you got some propsition for my problem?
Thank you very much
Message 6 of 9
(4,465 Views)
Bonjour,
Je vous suggère de jetter un oeil à cette KB : How LabVIEW Locates .NET Assemblies qui explique comment LabVIEW localise les assembly.net.
Cordialement,
Steve M.
Message 7 of 9
(4,453 Views)
Accepted by SonnyB
I'll answer in English, and hope that it can be understood, or at least translated for you. According to the translation, you are dealing with a static class. In this case, you do not create an instance of the class using the Constructor node. Static classes are not instantiated through a constructor. Instead, you directly call the method you want. So, you plop down a .NET invoke node, and then select the method directly from the class.
Message 8 of 9
(4,447 Views)
Thank you smercurio_fc, I can communicate with the automat now.
Message 9 of 9
(4,432 Views)
