LabVIEW 8.2 segmentation fault on Ubuntu Linux 8.10 64-bit
Hello Forrest,
This is the problm im gettting.
root@sankar:/home/sankar/LABVIEW8.6# lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
root@sankar:/home/sankar/LABVIEW8.6# nidaqmxconfig
nidaqmxconfig: error while loading shared libraries: libniorbu.so.1: cannot open shared object file: No such file or directory
While installing, i put --nodeps at the end of all comands. Will it miss any dependancy files ??
Have any idea how to solve  this ??
Help me how to unintall labVIEW and its all components???
Message 21 of 33
(2,943 Views)
I am sorry. I have told you that I have no idea abotu DAQmx on Linux. My guessing is that you forgot to install something related to NI DAQ driver. But according to the information you gave me, i can't help you more.
1. What is your Ubuntu version ?
2. Is your OS 32-bit or 64-bit?
Forrest Sheng Bao, Ph.D.
Assistant Professor, Dept. of Electrical & Computer Engineering
University of Akron, Akron, OH, USA
https://sites.google.com/site/forrestbao/
Message 22 of 33
(2,935 Views)
I m using Ubuntu 8.10 of  32 Bit version.
Wat that --nodeps means? And how we can Uninstall LabVIEW completely  ?? please clarify these also.
Thanks. Happy New Year..
Message 23 of 33
(2,926 Views)
--nodeps means install without dependencies. When you install with --nodeps, you can't see required packages for this package. I do --nodeps because LabVIEW RPM package echoed by "/bin/sh is not found". It is not a big deal and it is a mistake.
So, show me everyone on your shell window about how you installed DAQmx, with no --nodeps.
Message 24 of 33
(2,910 Views)
It's probably a good idea to try at first an install without -nodeps to get actually an idea of the possible problems. From there you can investigate the error messages and if it is indeed just the no /bin/sh or such then -nodeps should do the trick. But quite likely with DAQmx you have other dependencies that are much less harmless when not fullfilled or are not just imperfections of the install script itself.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 25 of 33
(2,894 Views)
Hello Forrest, I installed LabVIEW with the Gdebi tool.
FIrst I converted all the rpm files into deb format. then i used the Gdebi tool to instal. Just double click on deb file.
All the instllation went fine.
After installton i used the query, It didnt list the 2 devices i put on my PC.
1.PCI6514
2.USB 6008
I m using LabVIEW 8.6 package with Daqmx 2.1 version and the Laets ubuntu fully updated.
I dont knw how to solve this issue. Please help me.
Attached the snapshots here.
sankar.s
Message 26 of 33
(2,863 Views)
So we were not talking about the same stuff. Please do NOT use RPM2DEB package, but just rpm alone on Ubuntu. And use shell (a.k.a command line) please. What I asked is the full shell log. I want to see are the dependencies and the errors.
Show me the output of installing all packages you need via command lines without --nodeps. If you don't give me the information i need, i can't help you.
Message 27 of 33
(2,857 Views)
hello,
i just attached the labVIEW and device driver installation i followed.
please find the attachement, and help me.
sankar
Message 28 of 33
(2,839 Views)
Hello Forrest,
Here I sent the text of Installation  I did. I just tried with Older Drivers whether it detect the NI hardwares. I also downloaded the latest version of drivers. i will send that  after i tried.
LAbview Instllation
sankar@sankar:~$ sudo apt-get install alien
Reading package lists... Done
Building dependency tree
Reading state information... Done
alien is already the newest version.
The following packages were automatically installed and are no longer required:
linux-headers-2.6.27-7 linux-headers-2.6.27-7-generic
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
sankar@sankar:~$ cd ~/LABVIEW
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-rte-8.6.0-1.i386.rpm
error: Failed dependencies:
/bin/sh is needed by labview86-rte-8.6.0-1.i386
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-core-8.6.0-1.i386.rpm
labview86-rte is needed by labview86-core-8.6.0-1.i386
/bin/sh is needed by labview86-core-8.6.0-1.i386
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-rte-8.6.0-1.i386.rpm --nodeps
1:labview86-rte ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview-rte-aal-1.1-1.i386.rpm --nodeps
1:labview-rte-aal ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-core-8.6.0-1.i386.rpm --nodeps
1:labview86-core ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-pro-8.6.0-1.i386.rpm
nilvmerge is needed by labview86-pro-8.6.0-1.i386
sankar@sankar:~/LABVIEW$ sudo rpm -ivh nilvmerge-8.6.0-1.i386.rpm
/bin/sh is needed by nilvmerge-8.6.0-1.i386
sankar@sankar:~/LABVIEW$ sudo rpm -ivh nilvmerge-8.6.0-1.i386.rpm --nodeps
1:nilvmerge ########################################### [100%]
1:labview86-pro ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-appbuild-8.6.0-1.i386.rpm --nodeps
1:labview86-appbuild ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-desktop-8.6.0-1.i386.rpm --nodeps
1:labview86-desktop ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-help-8.6.0-1.i386.rpm --nodeps
1:labview86-help ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-examples-8.6.0-1.i386.rpm --nodeps
1:labview86-examples ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh labview86-ref-8.6.0-1.i386.rpm
1:labview86-ref ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh niwebpipeline20_dep-2.0-5.i586.rpm
/bin/sh is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6 is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.0) is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.1) is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.1.2) is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.1.3) is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.2) is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.2.4) is needed by niwebpipeline20_dep-2.0-5.i586
libc.so.6(GLIBC_2.3) is needed by niwebpipeline20_dep-2.0-5.i586
libdl.so.2 is needed by niwebpipeline20_dep-2.0-5.i586
libdl.so.2(GLIBC_2.0) is needed by niwebpipeline20_dep-2.0-5.i586
libdl.so.2(GLIBC_2.1) is needed by niwebpipeline20_dep-2.0-5.i586
libgcc_s.so.1 is needed by niwebpipeline20_dep-2.0-5.i586
libgcc_s.so.1(GCC_3.0) is needed by niwebpipeline20_dep-2.0-5.i586
libm.so.6 is needed by niwebpipeline20_dep-2.0-5.i586
libpthread.so.0 is needed by niwebpipeline20_dep-2.0-5.i586
libpthread.so.0(GLIBC_2.0) is needed by niwebpipeline20_dep-2.0-5.i586
libpthread.so.0(GLIBC_2.1) is needed by niwebpipeline20_dep-2.0-5.i586
libz.so.1 is needed by niwebpipeline20_dep-2.0-5.i586
sankar@sankar:~/LABVIEW$ sudo rpm -ivh nisvcloc-8.6.0-1.i386.rpm
/bin/sh is needed by nisvcloc-8.6.0-1.i386
sankar@sankar:~/LABVIEW$ sudo rpm -ivh niwebpipeline20_dep-2.0-5.i586.rpm --nodeps
1:niwebpipeline20_dep ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh nisvcloc-8.6.0-1.i386.rpm --nodeps
1:nisvcloc ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh niexfinder-base-1.0-11.i386.rpm --nodeps
1:niexfinder-base ########################################### [100%]
sankar@sankar:~/LABVIEW$ sudo rpm -ivh niexfinder-labview86-8.6.0-1.i386.rpm --nodeps
1:niexfinder-labview86 ########################################### [100%]
Message 29 of 33
(2,830 Views)
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisa-4.0.0-f0.i386.rpm
nipali >= 1.10.2 is needed by nivisa-4.0.0-f0.i386
/bin/sh is needed by nivisa-4.0.0-f0.i386
sankar@sankar:~/Daqmx/nivisa/nipal$ sudo rpm -ivh nipali-1.11.1-f0.i386.rpm
nikali >= 1.1.0 is needed by nipali-1.11.1-f0.i386
/bin/sh is needed by nipali-1.11.1-f0.i386
sankar@sankar:~/Daqmx/nivisa/nikal$ sudo rpm -ivh nikali-1.4.0-f0.i386.rpm
kernel >= 2.4.0 is needed by nikali-1.4.0-f0.i386
/bin/sh is needed by nikali-1.4.0-f0.i386
sankar@sankar:~/Daqmx/nivisa/nikal$ uname -r
2.6.27-9-generic
sankar@sankar:~/Daqmx/nivisa/nikal$ sudo rpm -ivh nikali-1.4.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx/nivisa$ cd nipali
bash: cd: nipali: No such file or directory
sankar@sankar:~/Daqmx/nivisa$ sudo rpm -ivh nipali-1.11.1-f0.i386.rpm
error: open of nipali-1.11.1-f0.i386.rpm failed: No such file or directory
sankar@sankar:~/Daqmx/nivisa/nipal$ sudo rpm -ivh nipali-1.11.1-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisa-4.0.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisa-config-4.0.0-f0.i386.rpm
nicvirte is needed by nivisa-config-4.0.0-f0.i386
/bin/sh is needed by nivisa-config-4.0.0-f0.i386
sankar@sankar:~/Daqmx/nivisa/nicvirte$ sudo rpm -ivh nicvirte-8.0-5.i386.rpm
/bin/sh is needed by nicvirte-8.0-5.i386
sankar@sankar:~/Daqmx/nivisa/nicvirte$ sudo rpm -ivh nicvirte-8.0-5.i386.rpm --nodeps
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisa-config-4.0.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisa-devel-4.0.0-f0.i386.rpm
labview80-rte is needed by nivisa-devel-4.0.0-f0.i386
/bin/sh is needed by nivisa-devel-4.0.0-f0.i386
sankar@sankar:~/Daqmx/nivisa/lvruntime$ sudo rpm -ivh labview80-rte-8.0.1-1.i386.rpm
/bin/sh is needed by labview80-rte-8.0.1-1.i386
sankar@sankar:~/Daqmx/nivisa/lvruntime$ sudo rpm -ivh labview80-rte-8.0.1-1.i386.rpm --nodeps
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisaserver-4.0.0-f0.i386.rpm
/bin/sh is needed by nivisaserver-4.0.0-f0.i386
sankar@sankar:~/Daqmx/nivisa/nivisa$ sudo rpm -ivh nivisaserver-4.0.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-board-support-2.1.0-f0.i386.rpm
/bin/sh is needed by nidaqmxbase-board-support-2.1.0-f0.i386
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-board-support-2.1.0-f0.i386.rpm --nodeps
[: 35: ==: unexpected operator
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-cinterface-2.1.0-f0.i386.rpm
nidaqmxbase-common >= 2.1.0 is needed by nidaqmxbase-cinterface-2.1.0-f0.i386
/bin/sh is needed by nidaqmxbase-cinterface-2.1.0-f0.i386
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-common-2.1.0-f0.i386.rpm
/bin/sh is needed by nidaqmxbase-common-2.1.0-f0.i386
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-common-2.1.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-cinterface-2.1.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-usb-support-2.1.0-f0.i386.rpm
/bin/sh is needed by nidaqmxbase-usb-support-2.1.0-f0.i386
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-usb-support-2.1.0-f0.i386.rpm --nodeps
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-labview82-VIs-2.1.0-f0.i386.rpm
labview82-core is needed by nidaqmxbase-labview82-VIs-2.1.0-f0.i386
sankar@sankar:~/Daqmx$ sudo rpm -ivh nidaqmxbase-labview80-VIs-2.1.0-f0.i386.rpm
labview80-core is needed by nidaqmxbase-labview80-VIs-2.1.0-f0.i386
Hope will giv some clear picture of the problem.
sankar.s
Message 30 of 33
(2,827 Views)
