02-13-2007 08:36 AM
02-13-2007 10:34 AM
The 3D graph is an ActiveX control. As such, it needs to be installed along with your application.
When you build the installer, you should have an option for including support for this option. This will install the control when you run your installer and it should then work.
If this doesn't help you, I suggest you try searching for more about this.
