LabVIEW 2020 TLS Question
Accepted by adekruif
Well if you use PASV, you are opening a second TCP cient connection to the server. The TLS negotiation mentioned in the RFC is what the Start TLS node does, just as it is done in your primary command connection too. So add that node right after The TCP Open Connection.
Rolf Kalbermatter  My Blog
Message 11 of 21
(3,806 Views)
I finally got it to work, after trying several different things. I ended up putting the start TLS in the open data connection.vi and it works now. Here is an example program for anyone else that may need this functionality.
Thank you so much for your help!
Message 12 of 21
(3,782 Views)
I am trying to test your solution but you need to attach these 2 vi.
AuthTLS.vi
FTPS-PBSZ.vi
Thanks for your help,
Message 13 of 21
(3,680 Views)
Those files are in the FTPS#.llb that I attached. Are you not able to get to the files from the llb?
Here are the two files as well if you can't get them from the library.
Message 14 of 21
(3,672 Views)
those vi are not in the libraries that you put.
Message 15 of 21
(3,668 Views)
The "FTPS Open Session" has AuthTLS as a SubVI.
"FTPS Security" has the PBSZ as a SubVI.
When I download the llb's from my earlier post, the two SubVI's are present in the VI.
Message 16 of 21
(3,661 Views)
the main vi FTPS Open Session and FTPS Security are inside the library but the sub vi AuthTLS and PBSZ are not, so when I open it from my PC it does not find them.
It is possible that these 2 sub vi are not in the dll but they are in your computer
Message 17 of 21
(3,657 Views)
Hello Sir,
I have the same problem but I'm using LabView 2016. Our IT changed some setting and made their server side to TLS so my default working program with FTP vi's does not work anymore. May I ask if which version of Labview has the FTP palette with the TLS option?
thanks in advance.
Message 18 of 21
(3,419 Views)
@NestorE wrote:
Hello Sir,
thanks in advance.
None! But LabVIEW 2020 supports TLS for the TCP/IP functions. You'll have to hack your own version of the FTP functions based on the discussion in this thread, using this feature. But you need to upgrade to LabVIEW 2020 for that.
Or buy the Encryption Compendium Toolkit here: https://lvs-tools.co.uk/software/encryption-compendium-labview-library/. It supports LabVIEW 2012 and higher.
Message 19 of 21
(3,410 Views)
I also cannot find these two VIs:
AuthTLS.vi
FTPS-PBSZ.vi
adekruif, I see that you tried to include snippets of them, but when I download them and drop them into the block diagram, the AuthTLS png just tries to load the AuthTLS.vi from <vilib>:\FTPAuthTLS.vi, which of course doesn't work because I don't have the VI in my <vilib>.
Would it be possible to drop the actual VI files into the forum? Much obliged! (and also for figuring out how to do this in the first place!)
Message 20 of 21
(3,313 Views)
