LabVIEW 2013 Slow When Using a Project
I have noticed that LabVIEW 2013 is pathetically slow when doing standard development from an open project.  Compiling, dropping VI's, etc., take seconds.   I never noticed it with previous versions of LabVIEW, and there doesn't appear to be a problem when I develop the same VI with the project closed.  I have seen some complaints about it, but not a lot.  I am using a new Laptop:  Windows 7 64-bit, 8-GB RAM, lots of spare disk space.  Any thoughts?
(4,034 Views)
That's not normal. Does the project contain any remote or inaccessible resources or similar?
(3,999 Views)
It happens with multiple projects.  I think everything is available.  Everything compiles fine and I can build installers and applications.  It is just the basic editing that is slow.
(3,982 Views)
A problem with an antivirus application?
Try reinstalling LabVIEW?
(3,967 Views)
Why only when using a project?  I will check it on a desktop PC and see if I get the same thing.
(3,956 Views)
You could try to mass compile your project to LabVIEW 2013 to force all VIs to upgrade:
Mass Compiling VIs
Taylor B.
(3,928 Views)
