LabVIEW 2013 SP1 Quit LabVIEW
Hello Ms. Kurz,
sorry for my late answer. Here is my MAX Report.
Heinrich Eidloth
Message 11 of 53
(1,725 Views)
Good Morning Mr. Eidloth,
thank you for your reply.
I will look into it right away and search for a solution.
Regards.
Veronika Kurz
Applications Engineering
www.ni.com/support
Message 12 of 53
(1,702 Views)
Dear Mr Eidloth,
did you get any error messages while building the exe?
Regards.
Veronika Kurz
www.ni.com/support
Message 13 of 53
(1,694 Views)
Good morning Ms. Kurz,
no, I got no error messages during the build process. The build completed without any errors.
The exe also starts without any problems and works as expected. Until I shutdown the exe.
Heinrich Eidloth
Message 14 of 53
(1,673 Views)
Hello Mr. Eidloth,
Thank you for your answer.
Are you able to run your code in LabView 2013 directly (without putting it into an executable)?
This will help me see if the problem is in the build process that doesn´t throw an error.
Regards.
Veronika Kurz
www.ni.com/support
Message 15 of 53
(1,664 Views)
Mr. Eidloth,
I was able to successfully run the Exe on LV 2013 SP1 in English. Do you also use LabView in the English version?
Veronika Kurz
www.ni.com/support
Message 16 of 53
(1,660 Views)
Hello Ms. Kurz, I can run the Software in the Development System. No problems. If I put a 'Quit LabVIEW' at the end of the shutdown process, LabVIEW will quit (as expected). Yes, I'm using LV2013 SP1 English. Regards Heinrich Eidloth
Message 17 of 53
(1,644 Views)
Hello Mr. Eidloth,
After talking with a colleague about your case I have following suggestion:
If possible install LabView 2013 SP1 with the drivers you need on a reference computer, that is free of any NI-Software and try building and running the executable again. We fear that the problem might lie with an interference of a previous version of LabView that disrupts the successful performance of your exe.
Please keep me updated about your progress.
Regards.
Veronika Kurz
www.ni.com/support
Message 18 of 53
(1,638 Views)
Hello Ms. Kurz, just for your information: The PC I'm using, is a 'freshly installed' one. No previous LV version was installed before. I did a test on a virtual machine (WinXP SP3, LV2013 SP1). The exe built on the virtual machine gave me the same result. The exe works properly, until I shutdown the program (no quitting). In the next days, I will setup a new virtual machine and will repeat the test. Regards Heinrich Eidloth
Message 19 of 53
(1,632 Views)
Hello Mr. Eidloth,
I´m very sorry but the Max-Report shows differently. Please try again to reinstall LabView.
Please excuse the inconvenience but right now we have to locate the exact source of the problem.
With kind regards.
Veronika Kurz
www.ni.com/support
Message 20 of 53
(1,624 Views)
