LabVIEW 2013 Applicatio​n Builder not licensed w/ Profession​al?.
Hi
We bought LabVIEW 2013 Full version and after installing found Application Builder is not licensed. Why?
 Victor
Serial number removed for security
(3,136 Views)
The "Full" version is not the same as the "Professional Development" version. The application builder is not in the Full version.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,134 Views)
This is strange Labview 7.1 Full version included it. How we can buy Application Builder?
Best regards
(3,123 Views)
A search in the LabVIEW Tools Network will get you:
https://www.ni.com/en-us/shop/product/labview-application-builder-module.html
(3,108 Views)
You send your recent serial number to NI, and they can give you a quote for upgrade from Full to Pro version, or also you can buy Application Builder separately. I think the price difference between the two options are not too large, so maybe you should considering to purchase Pro version.
Here you can check the differences between the Basic, full, pro, and developer suite versions:
https://www.ni.com/en/shop/labview/select-edition.html
here you can see the comparison table, so you can decide which features you need...
(3,107 Views)
You are also absolutely incorrect about the full version in 7.1. That version had the app builder separate as well.
(3,102 Views)
