LabVIEW 2012 Remote Front Panel
LabVIEW 2012 Remote Front Panel is not working. THis is after F3 service pack.
This issue is similar to the problem posted in KB:
http://digital.ni.com/public.nsf/allkb/EC7075355175D98E862577E3005254C2?OpenDocument
http://digital.ni.com/public.nsf/allkb/379E5C57148D877586256D6000632A3F?OpenDocument
The issue is about Remote Fron Panel showing white page with 0% of 0 Byte
It was not related to fire wall, not related to any of the permission problems posted in the boave KBs
Repairing LabVIEW 2012 and reinstalling F3 is not helping.
THis problem is new to 2012 version, it was not like this with 2011 version
I hope someone has seen this problem, it you have, please post what you have tried.
(3,638 Views)
Would it be possible for you to post your code and the html generated by the web publishing tool?
-Jake B.
(3,595 Views)
I am having a similar problem with LV 2012 trying to see the Remote Front Panel of my RT VI. I get an message about "Server Does Not Support Remote Front Panels", even though I installed Remote Front Panel Support to the target. This application worked fine in LV 2011. I attached my startup app for RT (running on pharlap target). I attached my startup exe/niwebserver.conf as well as my html file (which goes in ni-rt/system/www). I also included my original project in case it's easier to deploy and set the built item as a start up app from the project.
I did notice in MAX when I selected Remote Front Panel support to install to the target, there was a message about it only being supported with LV 2010 and the description said to read the notes about this, but I didn't see any.
Brad
(3,442 Views)
I am having a similar probelm trying to access to a remote panel of cRIO 9066. Always getting the same message 'Server Does Not Support Remote Panels'.
Using Labview 2014 Pro. cRIO has installed Remote Pannel Server for LabVIEW RT 14.0.0
Please any help would be appreciated.
(3,300 Views)
Hello TinoMK,
Have you consulted the following KnowledgeBase article yet?
"Server Does Not Support Remote Panels" Error When Connecting to a Remote Front Panel
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9zJSAS&l=en-US
Also, since this is an older thread in the forum, I suggest starting a new thread in order to get more attention and responses from within the community.
Erin D.
(3,258 Views)
