LabVIEW 2011 error code 3
I'm having a problem with a vi I recently created and will not open. I recieve the messsage:
"LabVIEW: Generic error.
An error occured loading VI 'DATTUS Data Mon.vi'.
LabVIEW load error code 3: Could not load front panel."
I've read through the discussion forums and have tried the "connPaneRecoveryMode=True to the LabVIEW.ini file" suggested in another post to no avail. I've also found document ID 250532 in the knowlege base of bugs and known issues but the workaround link is dead.
Please help!
(2,842 Views)
Your VI is corrupted. You will need to go to a backup.
You have backups, right?
And you are using sourc code control, right?
(2,839 Views)
Nope, this was the first version of the vi. I did created a back up in another directory but it has the same issue. It seems like from what I read this problem has something to do with the connector panes and I did make a change to the connector panes before before my last saving point. I'd like to know what I did wrong in hopes of avoiding this problem next time and also, in some of the other post I saw that a NI rep was able to recover these files so I was hopeful.
(2,828 Views)
