LVRT error treat_cpp Line 1938
This weekend two PC's, that run for about 4 weeks my application (using NI-6034, and a lot of math calculations including FFTs, storing data to HDD), stopped nearly at the same time with the same message: "LVRT error treat_cpp Line 1938". OS Win2k, LVRT Version 6.1.
Can somebody help me how and where to investigate what
it can be?
(2,672 Views)
Usually, errors like this have are an issue with a shared resource. I don't have a definite solution because I have never seen this error, but you could try the followingt:
Disable multithreading in LabVIEW. Go to Edit » Preferences » Performance and Disk (or Tools » Options » Performance and Disk , depending on your version of LabVIEW) and uncheck "Run with Multiple Threads". You have to restart LabVIEW after making this change.
Make sure that your DLL is "Reentrant". Right-click on the Call Library Function and select "Configure" from the pop-up menu. There is a pulldown menu with two options: "Run in UI Thread" and "Reentrant". Select "Reentrant".
If you did an upgrade, did you mass compile all your VIs after installing the update? You can read th
e on-line help in LabVIEW to learn more about how to perform a mass compile (Tools » Advanced » Mass Compile).
Have you changed the priority and/or execution system of your main VI or any of your subVIs? If so, change them back to the standard values and see if that solves the problem (File » VI Properties » Execution).
Also, try running the application on another computer, just to see if the problem has to do with the computer hardware itself.
(2,672 Views)
