How to identify the code used by a code interface node
I have an old Macintosh system running Labview 3.1.1 that contains CINs. How do I view the code used by these CINs or identify the .lsb files?
(2,865 Views)
I don't think that there's a way to do either. Even if you knew the name of the .lsb, the .lsb file does not have to be present after it's been loaded into the VI and you would still need the original C program to see the code.
(2,865 Views)
