LVBITX
hello all,
What is LVBITX file in Labview? How to open it?
Message 1 of 8
(2,780 Views)
@面包怪兽 wrote:
hello all,
It is a compiled LabVIEW FPGA file.  It is used to load an FPGA with the programmed personality.
Message 2 of 8
(2,775 Views)
thanks!
and then,what drivers do I need to instalI if I want to run these files?
Message 3 of 8
(2,721 Views)
@面包怪兽 wrote:
thanks!
You need LabVIEW-FPGA module to handle the FPGAs in your (NI) hardware targets!
Message 4 of 8
(2,709 Views)
@面包怪兽 wrote:
thanks!
Do you understand that this code is meant to run on an FPGA?
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(2,693 Views)
I understand that this file is related to FPGA.
When my program is running, an error message appears. I found that the file cannot be opened. I guess it may be related to this file.
Message 6 of 8
(2,667 Views)
Which error message do you get?
The error only appears when the program/VI is already running - or upon starting the VI?
You cannot access that file, not even with a simple ReadBinaryFile function in LabVIEW?
Or you don't know the file format and so don't understand its content?
You really need to learn to describe your problems better/more detailed…
Message 7 of 8
(2,661 Views)
I really don't understand his content,I am looking for the cause of the error in my entire program.Hopefully I can describe it clearly this time.
I am trying to control a myBOT,and I am using myRIO-1900
When I am trying to run the program. I encountered this mistake.
Then I open myBOT code,it throws an error that NI compactRIO Driver support of Labview 2018 is missing
I have installed the following drivers
I do not know how can I solve these problems,Could you give me some advice?
In the annex is my program,I look forward to your reply.
Message 8 of 8
(2,640 Views)
