Hello ben64.
While MS Office 2016 is not yet officially supported, our customers have been able to use the LV2015 RGT tools with MS Office 2016 without any problems.
There's no guide to which functions will work and which might cause problems, though! Using an unsupported version of MS Office may cause unexpected behavior.
My advice would be to test the specific functions you need - they'll probably work fine! But if you need reliability, I would stick with Office 2013 until a new version of RGT is released, including 2016 support.
Thank you,
Thanks Derek. I don't have access to Office 2013 for this particular PC (a licensing issue) so I had to install Office 2016.
I just wanted to know if somebody already tried it and encountered any issue. Hopefully everything will work fine, I'm using the RGT for very basic stuff for this project.
Thanks again.
Ben
The basic functions don't seem to be causing too much trouble! We've seen mostly edge cases here - but of course, if you run into trouble, feel free to post about it and we'll see what we can do 🙂
Have a great rest of your week!
So I found my answer in this other threads : http://forums.ni.com/t5/LabVIEW/Report-generation-and-office-2016/m-p/3360541#M988713 :
