LV2009: Graph->Copy Data moves/removes cursors
Using a right click->Copy Data seems to move or remove cursors from the image copied to the clipboard.  Anyone know of a workaround that doesn't involve screen cap and edit?
PrtScn result:
Copy Data result:
Other results show the cursor changing its value, but only in the vertical axis.
Joe Z.
(2,645 Views)
Okay, nevermind.  I can use a reference to the graph to get the image and flatten it out to a 2D picture and fiddle with it until I get it into the clipboard.
Interestingly, the private Export Image Color grabs the cursors correctly.  I guess that's not what Copy Data is using under the hood.
Joe Z.
(2,636 Views)
I have the same issue in Labview 2012 SP1. Sometimes the cursors get copied with, sometimes not. I have not been able to find when and why. Could someone help?
(2,585 Views)
This forum post is over three years old. In order for the community to better answer your question could you please post a new question and link this older post to it. This will allow it to appear nearer to the top of the postings. Have a great day.
Alex D
Systems Engineer
Academic Research
(2,566 Views)
