LV2009 32bit windows download
Good day,
i'm searching the download for LV2009 Windows vista 32 bit.
I must adapt such a project and wont want to upgrade right now.
thx
(3,290 Views)
Search NI.com.  Pick Downloads, and software to filter the list.  Eventually you find
LabVIEW Professional Development System 2009 SP1 - f5
(3,268 Views)
Thank You for Your answer, but the link You present is a patch, not LV2009 32bit itself.
(3,247 Views)
The fact that it is not available from NI's site for download probably means ... NI does not want you to download it (without a license).
Have you tried contacting NI directly and seeing if you could get it?
(3,220 Views)
If you have LV 2009 discs lying around, you could use them to install - provided, of course, that you have a valid license to use it with (which usually means any license that is newer than the version you are installing, provided there is still "room" on the license for another install).
Bill
CLD
(Mid-Level minion.)
(3,212 Views)
I'm sorry, but when I searched for it, it did not say it was a patch in the results.  The title says what is says.  And it doesn't say it is a patch.
(3,204 Views)
Accepted by kdCMC
The FTP site has it and the others - ftp://ftp.ni.com/support/softlib/labview/labview_development_system/2009/
From the size of the files there, I'm assuming it's just LV itself and that if you want other drivers or modules, you would need to navigate that tree and find their downloads. Like the others said, you would need a valid license to activate it.
___________________
Try to take over the world!
(3,186 Views)
