LV node GPIB control REN
Can anyone help me understand the different modes such as "Go to local" "Goto local; deassertREN" etc  in the LV node VISA GPIB control REN?
(3,475 Views)
The different options combine actions on the physical REN line that is part of the GPIB bus as well as standard commands. For example, to place an instrument into local control, the REN line is unasserted and then the GTL command is issued.
(3,471 Views)
Thank you, Denis
I have connected a powersupply in GPIB bus and I provided "Go to Local; Deassert REN" option along with its GPIB address. All the instruments in the GPIB bus has gone to local mode. I would like to know the reason why it has occured. Or how can i send local command to particular instrument connected to the GPIB bus.
Hemalalitha
(3,445 Views)
REN is a single line and affects all connected instruments. Issue a GTL only for just the addressed instrument.
(3,441 Views)
Can you please exaplin how to get back to remote mode?
(3,413 Views)
