[LV Memory Manager] uPtr data type
Could someone tell me the base data type of uPtr returned by the DSNewPtr function (http://zone.ni.com/reference/en-XX/help/371361N-01/lvexcode/aznewptr_dsnewptr/), where this is defined?
Looking at line 228 of the excode.h header file (http://zone.ni.com/reference/en-XX/help/371361N-01/lvexcode/labview_manager_functions/), it's of type uChar which is uInt8 and then uint8_t.
I think I must have made a mistake as I would have expected size_t for the uPtr data type.
(3,654 Views)
Accepted by matt.baker
The data you get from DSNewPtr is like the data you get from malloc, right? It's whatever you want it to be. malloc returns a void*, implying no particular size. Perhaps here they wanted to imply that you are getting size_t number of uChars.
(3,635 Views)
A pointer is typically a U32.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,630 Views)
Thanks. I guess that makes sense.
I hate to admit that I misread the uPtr typedef as a uChar data type rather than a pointer (size_t) to a uChar Smiley Embarassed
So the uPtr type when using the Call Library Function Node from LV should always be Numeric->Unsigned Pointer-sized Integer to let LV determine x64 or x86.
(3,620 Views)
