LV 8.6 library function in an example is not found
Several "examples" in LV 8.6 include a particular library function that is not found when I load the example VI. Where can I find this function? I have an "example" of one of the vi's attached containing the mystery function.
Thank you,
Chuck
(2,780 Views)
Accepted by chuck72352
If you want to load a state chart example, then you need to have the state chart toolkit installed. This is an optional toolkit that you have to purchase.
(2,776 Views)
Additional info: The Information text box on the Example Finder provides descriptions for the examples. If an example requires a toolkit and you don't have it installed, it will tell you.
(2,764 Views)
