Recently I again saw a strange occurrance that has happened to me about 10-12 times over the past year. Here specifically I am using LV 8.5 with the cRIO and FPGA module. When I was running a new RT VI from the developer environment, (deploying to the cRIO) the result looked something like this:
All the sub-VI front panels are opened, and shown in their reserved or running state.
None of these VIs are set to show front panel when called or opened, but all are sub-VIs of the top level VI within the project. It seems to have replicated a "Find all VIs in memory, within the project" and then "Show front panel" Invoke. The troubling thing is that this is not really repeatable, when I have closed all the VIs and run the VI again, it is fine. I have seen the same behavior in LV 8.2, 8.21 as well as when deploying to cFP-2120 or when on a Host computer.
Has anyone else seen this or are there any ideas of what is going on?
Mello
Message Edited by Mellobuck on
12-11-2007 01:17 PMMessage Edited by Mellobuck on
12-11-2007 01:17 PM
Data Science Automation
CTA, CLA, CLED
SHAZAM!
