LV 2012 Flatten To String / Unflatten From String problems
Accepted by Aalenox
Why don't you just use the Write to Binary File and Read From Binary File?  Then you don't have to worry about the flatten and unflatten.  But I have a feeling it is the "Convert EOL" option of the read and write to text file that is messing you up.
Message 11 of 12
(1,201 Views)
The read/write from binary file worked just fine. I can't believe I didn't think of that before.  It does still leave the issue of why exactly the other method wasn't working. Like I mentioned, it was the exactly what I'd used before in several different programs.  Thanks!
Message 12 of 12
(1,189 Views)
