LIST OF ALL DIRECTORIES IN COMPUTER
dear sir,
i want  a list of all directories in computer from all drives. Is it possible?
falgandha mohire
Message 1 of 9
(4,494 Views)
If you have a newer version of LabVIEW, you can use the tool "recursive file list" from the advanced file I/O palette.
Message 2 of 9
(4,490 Views)
And to get the info on all drives you have to feed an empty path into it.
Ton
(Be aware it might take some time)
My LabVIEW Ideas
Message 3 of 9
(4,479 Views)
thanks a lot
but i don't have newer version of labview. I am using labview 7.0 right now. please suggest me any another option. so that i can give only computer name and able to get all directories from all drives
pleas do the needful
falgandha mohire
Message 4 of 9
(4,465 Views)
Hi andheri,
      Maybe this will help.
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 5 of 9
(4,453 Views)
Message 6 of 9
(4,433 Views)
hello sir
I am using Labview7.0 for developing my application software.whenever communication failure/Power failure condition occures i want to display "COMMUNICATION FAILED" error to the user programmatically in my software. Please suggest any solution using which labview tools i can get the answer?
regards
vijeta
Message 7 of 9
(4,401 Views)
Your second post makes me think this is a network application, with the input of a computer name.  If that is true, then it is much more difficult, as you would need to set up the other computer to share all the drives, or have administrator access to the computer in question.  Ignore me if I am mistaken.
Message 8 of 9
(4,394 Views)
vijeta
Since this is a new question and not related to the directory listing question of this thread, you should start a new thread for it to keep everything on topic.
You should also specify how you are communicating with the devices.
Good luck!
Message 9 of 9
(4,375 Views)
