LINX function
Hi everybody,
How is the "ultrasonic HC-SR04" function of the LINX functions installed?
Thank you.
(4,046 Views)
I am using HC-SR04 sensor and LINX function. The distance was read via the ultrasonic function of LINX. But it was always 0. How can I read distance with the sensor?
Thank you.
(4,043 Views)
Hey star-123!
Can you give a little more background about what you're looking for? I'm not sure what you mean by how it's installed. Here's a reference for the function itself: link
I also might suggest posting in the forums over at LabVIEW MakerHub. They might have a little more info, depending on what you're looking for.
Claire M.
Technical Support
Certified LabVIEW Developer
(3,990 Views)
Hi star-123,
LINX is not an officially supported NI product so I would recommend posting this question directly to the LINX support forums to have the best chance of resolving this issue. The link to the LINX support forums is below:
https://www.labviewmakerhub.com/forums/viewforum.php?f=12
Applications Engineering
(3,986 Views)
