LED Question
I m using case structure.When its true, i m going to execute some sub vi and when its false, i m skipping the task and sending my error in dorectly to error out through case structure.
I wanna glow led with when its enters the case structure true status and stop glowing when it comes out of it.
And it should not glow when it is going through the false statement of case structure.
How to do this task
(3,911 Views)
Hi Sanjana,
see the attached picture please.
There is nothing in the false case.
Mike
(3,908 Views)
Hi mark
yes. there is nothing in the false state.it just routs the i/p to o/p.but when the case is true,i/p to case enters the sub vi and sub vi output is output of the case structure.
(3,898 Views)
Accepted by Sanjana
There is no need for any sequences. All you probably need is a single local variable.
Message Edited by altenbach on 02-19-2009 01:03 AM
(3,891 Views)
i m new to labview.can u please send me the vi (7.1 labview)
(3,868 Views)
LabVIEW 7.1 is ancient. We are 4 versions past that already. 😮 Sorry, I no longer have access to 7.1.
Well, there is no VI, just a rough mockup. It should be trivial to write things from scratch. I assume you already have your error wire, subVI and case structure. All you need is an extra local variable of the boolean. Should take literally seconds do wire up. have you tried? 🙂
(3,833 Views)
thanks altenbach,that was the solution.it is working amazingly.Smiley Happy
thanks mike for the suggestions...Smiley Tongue
(3,796 Views)
