LABVIEW controlled USB-to-SPI Hardware
Hey all! I'm trying to find a piece of hardware I can control via LabView that can send data via SPI protocol. It doesnt need to be anything special. I was using a FT232H chip but for the life of me I can not get it to work via LabView. Anyone know of anything. I know NI has some $500 dollar module but thats a hell of a lot more hardware than I need. Thanks!
Message 1 of 9
(1,417 Views)
you can try using an arduino for that.
Message 2 of 9
(1,414 Views)
This is a good reason start a open source project to build LV drivers for FT232H.
Santhosh
Soliton Technologies
Message 3 of 9
(1,395 Views)
Raspberry Pi would be another option if going on the cheap side.
GCentral
Message 4 of 9
(1,391 Views)
I need one of these as well and found several on Amazon.  I think I'm going to try out the Adafruit option though.
Adafruit FT232H Breakout - General Purpose USB to GPIO, SPI, I2C [USB C & Stemma QT] : ID 2264 : Ada...
This one uses the FTDI FT232H chip and is designed for control with Python code.  I can use Python but would rather have the option to control it with LabVIEW and C#/.NET as well.  I'll post back if I find better choices...
Message 5 of 9
(1,373 Views)
I had high hopes for the Waveshare products.  Especially this one ($21 at amazon😞  USB TO UART/I2C/SPI/JTAG - Waveshare Wiki
The Python example code just uses ctypes, so LabVIEW should be able to talk to it through a DLL, but there are no LabVIEW drivers I have found for any of these products.  That's not too surprising considering LabVIEW's popularity these days. ☹️
Message 6 of 9
(1,363 Views)
Here is a place to start: https://lavag.org/topic/19993-cr-mpsse-spi
GCentral
Message 7 of 9
(1,360 Views)
Can you expand on what is not working for you with the FT232H chip? AFAIK, the FT232 chip only does RS232, not SPI or I2C... but I could be wrong.
The FT4232 chip can do all the serial protocols, including SPI and I2C.
I am personally using a "FT4232H MINI MODULE" dev board from FTDI. Available from Digikey. About the same price as an R-PI but a lot less functionality.
Adafruit also has a "FT232H USB TO GPIO/SPI/I2C" adapter board. It is half the price of the FTDI dev board. Also available from  Digikey.
Hope this helps.
Message 8 of 9
(1,359 Views)
This is what I used when I wanted cheap SPI in the past.  An Arduino can be flashed with the LIFA, or LINX software, and then that toolkit in LabVIEW can be used.  I usually have difficulty figuring out various settings.  But once I got it working I was able to select the NI SPI hardware or Arduino one for projects.
Message 9 of 9
(1,327 Views)
