LABVIEW compatibility with AMD processor
Can LABVIEW be loaded on an embedded PC having an AMD Geod LX800-500 MHz processor. Plz help
Message Edited by vipinsaklani on 12-05-2008 12:57 AM
(3,715 Views)
If you can run a standard windows version (not CE)on your PC you may run labview on it. As I think the geode CPU is x86 compatible. But your CPU is to slow to use windows XP. You may consider using windows 2000 or windows 98, and perhaps labview 7.0 or 7.1. In any case your setup must have sufficient ram, HD, and CPU capacity for your project. If your computer runs windows CE 5.0 you may also use labview, but you need to buy a toolkit and transfer the aplication as an exe file to your host.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,685 Views)
