12-05-2008 12:55 AM - edited 12-05-2008 12:57 AM
12-05-2008 04:51 AM
If you can run a standard windows version (not CE)on your PC you may run labview on it. As I think the geode CPU is x86 compatible. But your CPU is to slow to use windows XP. You may consider using windows 2000 or windows 98, and perhaps labview 7.0 or 7.1. In any case your setup must have sufficient ram, HD, and CPU capacity for your project. If your computer runs windows CE 5.0 you may also use labview, but you need to buy a toolkit and transfer the aplication as an exe file to your host.
