LABVIEW SERIAL MODBUS
Message 11 of 15
(850 Views)
What is the make and model of the device you are trying to communicate with using Modbus?
=== Engineer Ambiguously ===
Message 12 of 15
(811 Views)
The issue has been resolved.
Changing the mode on both ends from ASCII to RTU solved the problem.
Message 13 of 15
(807 Views)
I swear I mentioned that...
@RTSLVU wrote:
Have you tried serial type RTU?
Anyway I'm no Modbus expert but to be honest I have never seen a Modbus device that used ASCII mode.
Message 14 of 15
(800 Views)
Yes, you mentioned it earlier, but the device manual explicitly states that "Modbus serial RTU and ASCII are supported." That's why I decided to try using ASCII. However, I still can't figure out why ASCII isn't working while RTU works perfectly fine.
Message 15 of 15
(772 Views)
