LABVIEW PDA/DAQmx Base error
I'm building a VI for a PDA (pocketPC 2003)
In a Functions Panel, when I'm going in a menu "Measurement I/O" => "DAQmx Base", it misses many icons. I have installed and uninstalled three time DaqmxBase 2.2 with the same result (icon.jpg). I have installed Daqmx Base 3.0 and the problem is always there. Moreover, when I'm going in menu "Select VI" in a Functions Panels, I can open anothers Daqmx Base VI, but there is many errors (error.jpg).
Labview 8.2.1
Labview PDA 8.2.1
DAQ6062E
(8,126 Views)
LabVIEW PDA support for DAQ is limited.  The number of DAQ VI's available on LabVIEW PDA is also limited.
I could not clearly view your error list but I did run across a possibly useful Knowledge Base article. I am also including the Known Issues with LabVIEW PDA 8.2.1 .
I hope this helps!
Ima
Applications Engineer
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(8,045 Views)
When I'm trying to use "DaqmxBase Create Task.vi", it seems to be unable to run correctly the subVI “System exec.vi” or to open systemexec.lsb.
Is there a list of available DAQBase VI's with LV PDA?
Thanks you
(8,043 Views)
The decimal symbol "." of regional options is already configurated as well ( Knowledge Base article ).
(7,981 Views)
Hi pctara6,
Please post a screen shot of the error code and message.  I will try and reproduce this error on my computer to see what is causing the problem.
Ima
(7,548 Views)
