12-04-2016 10:04 PM
Hello my Friends
I registered your network.
I just planing to start a project with NI cDOQ 9133 . I want use acceloremeter and strain gauge with this device.
I used Labview for signal processing at my university. For now , I have confused little bit.
Whats is the WES7 ? Does it come preinstalled , when I order ıt ?
If there is a link about this issue. I will be really appreciated with your reply.
Thanks a lot.
Solved! Go to Solution.
12-04-2016 11:24 PM
WES7: https://www.microsoft.com/windowsembedded/en-us/windows-embedded-7.aspx
When you buy this cDAQ device, you have to select which OS you want it installed with: Wes7 or Linux RT.
12-05-2016 03:24 AM
Thank you.
Best Regards
