Kinect 3D modeling
Hi everyone,
I'm using Kinect and trying to make the 3D modeling by Kinect follow this tutorial https://decibel.ni.com/content/blogs/MechRobotics/2011/04/19/kinect-6d-visualization-in-labview
I installed all neccessary programs including OpenNI, PrimeSensor, Nite, NI IMAQ... and this tutorial https://decibel.ni.com/content/docs/DOC-16978 works on my system very well. However, the tutorial (3D modeling) above didn't work. When I run this program, even error didn't appear but the screen is still dark. In addition, when I plug out Kinect, error also didn't appear. I wonder whether this progam can't connect with Kinect. I hope you can help me indicate the mistakes.
Please let me know if any clarification is needed of my issue.
Thank you so much and looking forward to hearing from you
Mina
---Let it works---
(3,325 Views)
No errors? Oof, I can understand your frustration. It looks like there is a driver required. Did you install that?
http://ryangordon.net/2011/01/20/kinect-for-labview-part-2/
Ben D.
(3,295 Views)
Thank you so much for your help
I'm trying to install this library. However, regarding to this library, all the VIs example were removed. Follow the README file, I copied some file to system32 and system32/driver but it still didn't work.
If possible please help me overcome this tough time.
I'm looking forward to hearing from you
Thank you again
Mina
---Let it works---
(3,275 Views)
I regret to say we do not support these 3rd party devices. If you are having a particular error, we can definitely help you with that.
Ben D.
(3,254 Views)
